When it RAINS ! The skies get insane with opportunity to caputre something interesting. i wil post the video in a few days as there is a lot to unpack. Its 2 am the Mavic 3 Pro is geared up with the Wet Suit an ready at 4k 60 Frames with 3 x zoom and the Rain is coming down in sheets...
mavicpilots.com
Phantomrain.org
Gear to fly your drone in the Rain. land on the Water
I haven't looked at it frame by frame, maybe I should. I shot it at 30fps. I should have changed it to 60fps, but was in a hurry to capture it and flying blind in the dark.
Someone on the Forum said that you can also get good Frames from 30 , so I have a Trick I use to find the Frames I want to post.
Quick Tip:
When you bring the Video into the time line , Take the whole Video and Slow it down to 30 % , this will allow you to see the Best parts quickly when you scan the time line for the action , other wise its very hard to see and you will scroll right past it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
