Hello from Atlantic Beach, Fl
am a Novice and just got my Part 107.
Congratulation on getting your Part 107. You did not say if you have a drone but you did post in the Mavic 2 Sub Forum… As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you are flying the Mavic 2, then it weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
But with a Part 107, any drone, no matter how light, if used under your part 107, must be registered…
To put it more clearly, if you have two drones, the M2 and yu use it for business and you have Mini 2, but you only fly it for fun, then theMini 2 does not need to be registered, but if you use both for business then both must be registered and you would also need to buy a separate RID module for the Mini 2
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 2, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
henryairsoft1
