Hello from Australia
Welcome to the forum! :)
welcome to the forum ,this forum is certainly the place to gather knowledge,and also impart it as well
Hello from the Crossroads of America GeorgeM.
Nice to meet you George. 👍
Welcome to the Forum. :cool:
I'm still trying to learn the drone.
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Welcome to the Forum!
"I'm still trying to learn the drone."
I'm always curious, you have a drone or looking to learn more.
48?
I tell people, if there age is over the speed limit, you have the right to drive your age.
You got a ways to go, I will be there before you. :rolleyes:
Dang, I wrote this out and then realized your in Australia, before I made the post.
Hope your better with conversions than me.:)👌
Rod ..
Welcome to the forum George.
This place is an awesome learning centre, along with Youtube tutorials.
Also download the full manual (if you haven't already) and read up, save to your device for on the go reference.
You probably got a yellow CASA rules pamphlet with your drone, covers the basics, good to go to CASA website and check out the apps there for use before flying an area.
greg190
