Hello from Croatia
Welcome to the forum! :)
I am flying DJI Mini and Mini 2SE
Since you live in Croatia, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the links to all of the downloads offered by DJI for the Mini and the Mini SE, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Thank you for all the information. I have to say, guys like you make me feel welcome.
Reactions: LoudThunder
mandeh
