Hello From Illinois!!
Kai12
Illinois, USA
Im located about 30 miles outside of the city. Im certified 107 and fly everything from DJI to microdrones and racing drones. I fly for fun and finance. Have been shooting for about 6 years or so. Main drone income is from live events and love it. So happy I could find a hobby that is so cool. Fly To Live - Live to Fly Aces High!!!
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
https://mavicpilots.com/dbtech-membermap/
Happy Droning…
Hello from the Crossroads of America Kai12.
Welcome to the Forum. 😎
Welcome to the forum! :)
Is there a way to add myself to the map?
I found you. 👍
You must drag the pin to a specific location if you wish to change it.
Map isn't working for me. I also don't see a menu option in the members section as well.
Found you too. :)
Your pin is in Portland.
Move it across the border if you want.
Welcome to the forum. We look forward to your participation and your view of the world.
If you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in South Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
If you have a drone know, let us know and we might be able to hook you up with some great Links…
Happy Droning…
Welcome to the forum from your fellow Illinoisan in the Joliet/Plainfield area.
Joe Duhr
