Hello from Lehigh County, PA
wags1
Kutztown, PA
Ordered a Mini 2 , couldn’t pass up the Amazon Prime day sale! Been doing lots of reading and watching YT videos to get ready to fly. Have my TRUST Cert and looking forward to my first flight. I have lots of places around where I live that should be good for flying.
Hello from the Crossroads of America wags1.
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Congrats, you have your TRUST Certificate. Your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, so you are not required to register your Drone. However, I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in Pennsylvania, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
volidas
