Hello from Manchester uk
Hello from the Crossroads of America mallymal
Sorry about your loss.
Making up for lost time on holiday in Portugal, but suffered a SEA CRASH 😢😢😢
Will upload footage & description in another thread
This site provides information that may help decipher what happened during the flight.
Follow the instructions and share the link if desired.
There are members here that can break down the information provided.
Good luck and welcome to the Forum. 😎
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum! :)
Hi folks
mal here from Manchester. Got me a Mavic Air about 3 years ago, but not had muc( chance to fly it due to lockdown.
Will upload footage & description in another thread 👍
Hi and welcome to the forum from South Wales, hope you enjoy cheers Len
Got me a Mavic Air about 3 years ago, but not had much chance to fly it due to lockdown.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current. As you've said you've had it a while, but be sure to fly legally… You do not want the Drone-Bobbies knocking on your door…
Where you able to recover the Drone from the "old man" of the sea? For all to know, the salt in sea.ocean water can cause so mach damage sometimes it's easier to just put your drone in a small basket and set it on fire and return it to the sea like a Viking funeral…
But, sometimes, you can soak it really good with fresh water to rinse out the salt water and then blow it out with a vacuum cleaner on blow, not suction, then bury it under a bucket of rice to soak up all that moisture. Sometimes the rice gets so saturated, you have to put the rice in the oven for an hour to dry out and then when it has cooled back down, re-bury that drone. The worst that can happen is you waste a couple of pounds of rice…
Whether or not it was recovered and in case you are getting a new one, here is some Good Old Fashion Advice that might help you keep your next drone dry…
Below is the link to all of the downloads offered by DJI for the Mavic Air, including the User Manual.
Happy Droning…
NotSure
