Hello from Maryland, USA
Welcome to the forum!
So others know you all ready been busy on this forum. 👌
Rod ..
Looking forward to interacting on this forum with fellow drone pilots
As a New Drone Pilot (from one of you other postings for the Mini 4, but your Air 3 experience?) there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds) with the little battery, and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Maryland, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro And Air 3, including the User Manuals.
After you read the Manuals, read tehm again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Hello to all drone enthusiast. Looking forward to interacting on this forum with fellow drone pilots on all drone issues.
Welcome! I’m in Howard County so feel free to reach out and connect. Recommend you also follow Maryland Drone Pilots FB groups.
Also from Maryland, welcome to the MavicPilots forum! Enjoy safe and happy flying.
Welcome to the forum! :)
Welcome to the forum from the bowels of California!
Photogeezer
