Hello from Ottawa Ont. Canada.
Status
Not open for further replies.
Just received my first drone, a DJI mini3 pro and there is a lot to learn but so far I love it!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Greetings from Birmingham Alabama, welcome to the forum!
Status
tocotco80
