Hello from Queensland in Aus
kazaly
Brisbane QLD, Australia
I'm looking to get into a DJI drone, probably an Air, so shopping around.
I found a cheap 2S online but it's account is locked though I have been given the serial number.
Is there a way I can contact the account holder?
If, as I suspect, the drone is stolen, I could hopefully reunite it with its original owner.
(the drone is currently for sale by a pawn shop).
If it's not stolen I'd be more than happy to make it mine!
How do I go about contacting DJI re the matter?
Hello from the Crossroads of America kazaly
I can't help you with your questions, but others may have the information you need.
Welcome to the Forum. :cool:
Thanks so much for the warm welcome from the heartland MA2 317
Welcome to the forum! :)
DJI would be able to tell who last registered it, but not sure they would help you. It would be better to buy a drone that you know isn't stolen.
I wasn't going to buy it.
If I can find out who owns it though, I can either let them know where their drone is or let the local cops know if in fact DJI are willing to divulge ownership details.
I'd guess the drone has been stolen as the account has been locked in much the same way as a mobile phone can be remotely locked via its IMEI number.
What I was hoping for, is that a member here may have information on how to go about contacting DJI about this sort of thing.
Greetings kazaly, welcome to the forum from the Northern Territory.
If you’re not sure, don’t buy. I’ve only once heard of a drone being reunited with its owner in the manner you are attempting. Move on, plenty of drones out there looking for new owners. Just be careful, it can be addictive.
Regards
Welcome to the forum from the beautiful woods of Maine!
I’m not sure if there’s an easy way to find that info but I would walk away from the pawn shop myself.
Reactions: LoudThunder
Welcome to Mavic Pilots!:) Enjoy the forum!Thumbswayup
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
I found a cheap 2S
In case you do decide to go for the A2S, I've included the Download Link from DJI for all of its links…
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy Droning…
If you search our Lost and Found Sub-Forum, you will see that DJI is not the easiest entity to get that type of support from. I was on eBay and saw a listing for a Mini SE that the seller said they found while hiking, the auction even listed the serial number, I published the Ad on our web site and I even contacted DJI and asked them to contact the original owner since all of the Drones are registered by serial number to email accounts and they did, reluctantly but I do not know the outcome. The Drone did sell, but I do not know if the original owner got it…
You see, unlike your old Australian Penial Colony rules and laws, "Theft by Finding…" here in the states, it's pretty much "Finders Keepers, Losers Weepers…"
Also, buying a used DJI Drone off eBay, sight unseen, is fraught with danger, besides the possibility of a stolen drone, there is the possibility that the drone is still "bound" to the original owner's account and the drone may never be truly yours…
Search our database for more info on this subject or view various YouTube Videos for first hand accounts.
Good Luck!
Reactions: dirkclod
phoenix_00002
