Hello from Türkiye...
Hello from the Crossroads of America erolkan.
Nice to meet you Erol. 🤝
Welcome to the Forum. :cool:
Welcome to the forum! :)
Welcome to the forum. We look forward to your participation and your view of the world.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Turkey, there are specific laws and rules for you to follow, please check to ensure these are current.
From your second posting concerning the FCC Mode in you drone, it sounds like you are an experienced flyer, But Good Advice is never out of place…
Below is the link to all of the downloads offered by DJI for the Mavic Air, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: Steel63 and Gagey52
KarstenG
