Hello from the UK !
James1984
United Kingdom
Good evening from Suffolk in the UK.
I’m a Proud owner and responsible operator of a DJI Mavic Mini 2. I purchased this drone to come along on my landscape photography adventures to give an added element of enjoyment. Since becoming a “mavic pilot” my DSLR has barely been out of its bag! I’m hooked on flying this incredible little drone!
Looking forward to interacting and sharing content with the community 👍
James
James
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello and welcome from Savannah, GA on the US east coast! Hope you're enjoying your mini 2 as I really loved mine. I've since replaced that drone with a Mavic 3 and absolutely loving it.
If you ever have any questions about your drone OR photography, this is the place to be. Everyone around here is so full of helpful information that I'm learning something new every day!
Hope to see you around here. Good Luck! :)
I also fly the Mini 2 and I've included a link to all the DJI Downloads for your little bird. Be sure to name your bird…
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Welcome to the forum! :)
James
Hi and Welcome to the forum, yes a brilliant little drone, excellent for photography, hope you enjoy our forum, cheers from Len in South Wales
Midlifecrisis77
