Hello from Victoria..have a problem with connection with DJI mini ..aircraft flashing green lights and the controller's lights stopped blinking and not connected.. what can I do to connect
Thank you
Thank you
I bought it through Kogan .. refurbished from DJI..the tutorial is experiencing a few problemsWelcome to the forum Blu.
Suppose you are using Fly app correctly and following DJIs instructions ?
It sounds like it's a binding (linking) problem between aircraft and controller ?
What's happened to cause this, new aircraft or controller ?
(Usually they are bought / arrive all ready to go, matched up / linked from the start.)
Check this DJI tutorial quickly to see if this is what you are experiencing, and if so, if any info there can help.
Should be linked already then, refurbs from DJI are set up ready to go like new ones.
If they missed it somehow, it should be straight forward like the tutorial.
That's not playing for you ?
If you can try that process specifically and still no luck, might be time to call Kogan and arrange a replacement, should be fairly simple to get an exchange one which hopefully is ok.
The video is a good starting point, it SHOULD be in post #2 for you to watch right there, minimised or maximised, or you can click the appropriate link bottom right and watch on YouTube.
I'll post link here with a break in between . com, just cut & paste that into a new browser window, remove the space, and see if that works.
https://www.youtube. com/watch?v=L_EC61fzeUc
Maybe mention here you have the latest Fly app downloaded ok, and what device (phone or ipad / tablet you are using.
Thank you very much for the link.. I am using Xiaomi Pocophone MIUI ..I have reinstalled the app.
Thanks again
