Hey from Australia!
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. We look forward to your participation and your view of the world. You will find plenty of support and help on the forum.
Greetings from Birmingham Alabama, welcome to the forum!
I'm new here and I bought my DJI Mini 2 about 5 months ago. I just want to become a pro, I hope I'll get the help I need here!
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Living in Australia has some rules and laws you need to follow…
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
jigjjihhwohekjgh2857
