Hi from Coventry Uk
GREEBO_22
COVENTRY UK
Hiya,
Finally got round to getting a drone so went and bought an Air 2s last week, Got a Flyers ID & Operators ID joined FVP UK and then found out about Cx markings and regs from Jan 2023 ( but there seems there may be a reprieve) looking at doing the A2 C of C but think thats changing in 2023 too but cant find the page i read about it again
But in the meantime,, Fly & Smile
Welcome to Mavic Pilots!:) Enjoy the forum!Thumbswayup
Welcome to the forum, great bunch of people, friendly and helpful.
Yeah i would hold off on anything for the moment until the DFT make a decision unless there is a legal requirement for what you want to do.
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
It sounds like you've been busy, time to relax and enjoy that Drone
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Below is the link to all of the downloads offered by DJI for the Air 2S. You will also find the 57-page Air 2S's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Air 2S - Download Center - DJI
Happy and Safe Droning…
Hiya,
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
Welcome to the forum! :)
ryanhafeman
