i'm enjoying with my
air 2 and hope to have more fun going on the way,
mavicpilots.com
Since you live in Italy, there are specific laws and rules for you to follow, please check to ensure these are current.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic Air 2, including the User Manual.
At DJI Download Center, Learn aboutMavic
Air 2
www.dji.com
Fly On and Fly Safe…
