Hi from Italy
Benvenuto nel Forum!
Quanta esperienza hai pilotando queste cose?
I buoni giorni possono andare male, molto velocemente!
Se riesci a trovare le tue risposte, chiedi.
Più importante!
Stai lontano dai magneti Mavic🌲
Asta ..
Salve, non ho molta esperienza con i droni "professionali", sono qui per imparare 😉
Reactions: LoudThunder
Hello from the Crossroads of America RustyN4il.
Hello everyone, I'm the lucky/unlucky owner of a Mavic pro Platinum! I hope to learn a lot in this forum! Thank you
Yep.
It's a love / hate relationship. 🙃
Welcome to the Forum. :cool:
Since you live in Italy, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic Pro Platinum, including the User Manual.
Fly On and Fly Safe…
Grazie per le preziose informazioni, ne farò tesoro. Ho già pilotato alcuni semplici modelli di droni, ma questo sembra davvero buono e ben costruito. Mi eserciterò il più possibile 😉
Welcome to the forum! :)
Photogeezer
