HI From UK/Sussex
NorbertG59
UK
I have been flying the cheap (Chinese $200 Drones) I think I'm ready to learn more with DJI Drones, so bought a Mavic pro Platinum with only approx 10hours usage
Hoping to improve more
Regards
Regards
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Pro Platinum , including the User Manual.
Happy Droning…
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Welcome to the forum. We look forward to your participation and your view of the world.
Regards
Hi from Len in South Wales , hope you enjoy the forum, happy flying
Regards
Hello from way away in the bogs of Savannah, GA USA.
I couldn't be more excited to see some pics and/or vids from your neck of the woods across the pond!! I bet you have some real History to show off!
Thanks, and welcome to our friendly little Oasis out here in the net...
Welcome to the forum, you will enjoy your new drone, I'm sure of that. I lived in Selsey Sussex for a several years (76-79). Love Chichester.
Reactions: LoudThunder
jw312569
