Hi from Vermont, USA
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. It's fun communicating with other pilots here. Mini 3 pro is a great drone to play with. If you happen to look for a handy case to carry and protect it, check out our MM330 hard case. Enjoy!
Greetings from Birmingham Alabama, welcome to the forum!
I got a new Mini 3 Pro with the new RC controller. I completed the TRUST certificate and have registered with the FAA as I am within the restricted zone around an airport. I am just looking to have some fun while bringing a new level to my photography.
Hey MM,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Good on you for getting the TRUST and Registration out of the way. I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer. Be sure to keep you certificates (or copies…) with you.
You wrote that you are within the restricted zone around an airport. Since you have an account with the FAADroneZone, you might be able to get a "Certificate of Waiver or Authorization" from the FAA through the DroneZone. I've applied for numerous waivers and everyone has been approved, the worse cases were change of dates or radius of locations. In fact, just this week, the FAA sent me notices that three of my year-long waivers are about to expire and do I want to renew them…
Here is the link to my "New Pilot Submission" and you can see from the map I attached that I have my own issues…
Since you are so proactive with the paperwork and with your interest in Photography, If you consider selling or monetizing your videos on YouTube then you will need to get your Part 107 License, here is a link to get you going…
Since you live in Vermont, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
Welcome to the forum! :)
ParHunter
