Hi new
Hello from the Crossroads of America disisme.
Nice to meet you Lynn. 🤝
Welcome to the Forum. :cool:
Hi, Lynn! Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon add a Mini 3 Pro to my “fleet”.
We have over 150,000 members—many from your part of Canada--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy. They specifically refer to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
Welcome to the forum! :)
Hi new from Ontario Canada
Lynn
Hi Lynn,
Welcome Back, You first joined last month, tell us something about yourself, what drone are you flying if you have bought one…
Any case, I'll sent you my full Welcome Note again…
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
AVI Drones
