Hoi from Holland
Klaaz
Nederland
Hello, I'm from the Netherlands en I just bought my 3e drone...
The first was a really cheap one with no auto functions at all, very difficult to fly but a great learning-drone!
The second was a JJRC X11, fly's really good whit a lot of functions but the camera is low quality en there is no damping or stabilisation at all.
The third is a Mavic Mini!
I hope I can learn a lot on this forum!
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Welcome to the forum. I fly the MM and have enjoyed many fun flights. You will find helpful suggestions and advice. We look forward to your view of the world.
Welcome to the forum! :)
Three years further............. I had the Air 1, Phantom 3 advanced, Inspire 1, Spark, Tello and the Pro 1.
All sold.
Since a month I have the Pro 2 and a Mini 2, both flying on the Smart Controller RM500.
Great set!
I missed you three years ago, so...
Hello from the Crossroads of America Klaaz.
Good for you keeping the spirit of flight as you work with different models of aircraft.
Although belated, welcome to the Forum. :cool:
Hello, I'm from the Netherlands en I just bought my 3e drone . . . The third is a Mavic Mini!
Since you live in the Netherlands, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
i welcomed you the first time in 2020 see post #5 above
so welcome back on your return enjoy your return
SK farming
