How to take multiple exposures?
Ged73
443CD109-B175-4EB0-94D1-B253D33C2509.jpeg hi, I’ve had the Mavic pro 1 week & its a great piece of kit added to my cameras, took a fairly nice beach shot, sharp and slightly adjusted in Lightroom. But I can select multiple exposures, but then in light room the 3 images look like they have the same exposure? How can I adjust this on the control (phone)
Thanks, Ged73
There should be I think 1 stop difference between shots. Maybe try AEB with 5 shots and see if you can see the difference then??
Reactions: Ged73
Thanks mate, will give that a try Saturday, like you said, might be more noticeable?
I have the same issue (they all look like the same exposure). I just merge the 3 images to HDR in LR and it works out fine.
The "Multiple" mode is just a burst mode for taking several shots at the same settings. AEB (Auto Exposure Bracketing) is the definitely setting you want to use for taking multiple shots at different exposures.
You can use the multiple mode to take 25-30 quick shots at the same location. Then by stacking them you can get a photo with higher density having the the effect of a much higher megapixel photo.
I’m an idiot! How’d I not see that? Thanks pal
That! I have to try, no grain issues ?
Faustino
