Howdy from Studio City, CA
pili191604
Studio City, Los Angeles, CA, USA
I've been in CA for about 4 years and in Studio City for about 2 years. I have a Mavic Mini and I'm posting to this forum to see if anybody knows any good drone flying places in my area. The is a dedicated R/C flying field I can go to, but the "drone area" has been taken over by FPV pilots.
Just looking for other options where I can get my drone in the air and don't have to worry about harassment.
Thanks
Welcome to the forum! :)
I assume you have tried the RC field just south of Van Nuys airport? Didn't know FPV had taken it over. We have a member on the forum that posts many fine videos from his flights just north in the valley. Maybe he will weigh in. I also live in Studio City but tend to fly on my travels
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Happy Droning…
smittysflying
