I introduce myself
Hello everyone, I've been a passionate drone pilot for several years, I started with helicopter models without gyroscope and now I own a Mavic 3 and a Mini 2...Thank you for welcoming me to the forum!
Greetings from Italy, the Marches.
Greetings from Birmingham Alabama USA, welcome to the forum!
And Merry Christmas!
Since you live in Italy, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2 and the Mavic 3, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy Droning and Buon Natale …
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the best forum on the web for drone operators.
Prits_uk2002
