IMU and compass calibration issues after firmware update
Theo13
right after I upload most recent firmware, I get a system warning- check app message
system status shows I need to calibrate compass and IMU gimbal connection issues and accelerator... issue
when tryinfg to initiate either calibration I get no response
DJI online tech support had no possible answers other than to send it in for look!...?
Just do the calibration,
how To is explained in YouTube, that should work,
Imu is more important do it first.
I have tried that many times...turning off and back on etc..
when I tap the START on either IMU calibration or Compass I get no response
It will not go into the calibration sequence
Controller continues to message: "System Warning" "Check App" and when I touch GO FLY it reads Red message of "Controller Data Error"
thanks
thanks
Something odd is going on there.
Normally there is no need for, or reason to recalibrate anything after a firmware update.
Reactions: TnDronePilot
Having the same issue here using the smart controller. Red warning on controller says to calibrate IMU. Click on the warning and it takes me to the IMU section, but the option to calibrate doesn't pop up and the calibration sequence doesn't begin. Nothing happens.
Same here. IMU will calibrate for a few minutes then sends out a -13 error on my smart controller. It worked great for a year until I updated my software like it asked. Just want to fly again. Any ideas?
joel_du05
