IMU and Compass error with lost of GPS signal
Fire Fox
South Africa
I took a flight today and everything was perfect on the preflight check and home point was updated. This was my 4th take off for the day but then when I got about 100 meters away I got and IMU heading error with a Compass error and weak GPS signal but there were 17 satellites then another compass error and an aircraft signal too weak error and she switched to Atti mode. So I turned her around and headed back but then as she was nearly back GPS was back and everything was fine and I continued to fly like normal and back out over the same area I was at no more problems. Has anyone experienced this does it mean I should recalibrate everything even though it was working fine after the problem?
For me that directs to a different URL that reports the linked site to be a known phishing website.
I think you should be able to see the flight log now on this file. It looks like it was a yaw error That caused it. Not sure what causes that and how to prevent it from happening again
334002020-03-19 15:23:02-26.091268807499528.150467590730470.8661445187.868379266425.0089892202.42848416816511.2585188.852631266471.85039625.0089892202.428484168-19.685072-15.434886-0.223694216.3-4.34.20016841024102410242160413.7333.7323.7250009.118109.945187.868379266470.8661446P-GPS
335002020-03-19 15:23:02-26.091277245913928.150458115633670.8661445187.868379266424.9866198206.60040031216511.2585188.852631266471.85039625.0089892206.600400312-19.461378-15.658580216.3-3.94.40016841024102410242160413.7333.7323.7250009.118109.945187.868379266470.8661446P-GPS
336002020-03-19 15:23:02-26.091285442380628.150449221189871.1942285188.196463266424.941881210.61253954816511.2585188.852631266471.85039625.0089892210.612539548-19.237684-15.882274-0.223694216.3-3.34.40016841024102410242160413.7333.7323.7250009.118109.945188.196463266471.1942286P-GPS
337002020-03-19 15:23:02-26.091293468446928.150439711856271.1942285188.196463266424.8076646214.67323521616511.395188.852631266471.85039625.0089892214.673235216-19.237684-15.65858-0.223694216.3-3.43.60016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
338002020-03-19 15:23:02-26.091301707748228.150430352439971.1942285188.196463266424.494493218.7860962416511.395188.852631266471.85039625.0089892218.78609624-19.01399-15.434886-0.223694216.2-2.93.60016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
339002020-03-19 15:23:02-26.091308850650828.150421471881571.1942285188.196463266424.1813214222.47999399616511.395188.852631266471.85039625.0089892222.479993996-18.790296-15.211192-0.447388216.1-3.13.50016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
340002020-03-19 15:23:02-26.09131623883628.150412649230171.1942285188.196463266423.8905192226.24967915616511.395188.852631266471.85039625.0089892226.249679156-18.790296-14.763804-0.223694216-3.64.10016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
341002020-03-19 15:23:02-26.091323391170528.150403183383971.1942285188.196463266423.8905192230.05610972416511.395188.852631266471.85039625.0089892230.056109724-18.566602-14.54011-0.223694215.8-3.72.40016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
342002020-03-19 15:23:02-26.091330621826628.150394235572671.1942285188.196463266423.4431312233.81004685216511.395188.852631266471.85039625.0089892233.810046852-18.566602-14.3164160215.6-2.81.60016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
343002020-03-19 15:23:03-26.091337527888328.15038484491471.1942285188.196463266423.1746984237.54200235216511.395188.852631266471.85039625.0089892237.542002352-18.566602-13.8690280215.7-2.42.40016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
344002020-03-19 15:23:03-26.091344442704428.150375989608871.1942285188.196463266422.8615268241.1942334416011.395188.852631266471.85039625.0089892241.19423344-18.342908-13.6453340215.7-2.63.10016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error. Aircraft GPS signal too weak. Home Point not updated.
345002020-03-19 15:23:03-26.091350927767728.150366750736771.1942285188.196463266422.7273104244.783472416011.395188.852631266471.85039625.0089892244.7834724-18.342908-13.421640215.8-33.50016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
346002020-03-19 15:23:03-26.091357457020428.150357992019571.1942285188.196463266422.4141388248.31168773616011.395188.852631266471.85039625.0089892248.311687736-18.119214-13.1979460215.7-3.53.80016841024102410242160413.7353.7353.7270009.118109.945188.196463266471.1942286P-GPSYaw Error
347002020-03-19 15:23:03-26.091363492737328.15034887094571.1942285188.196463266422.2799224251.75558548416011.395188.852631266471.85039625.0089892251.755585484-18.119214-12.974252-0.223694215.7-3.74.10013521024102410242160413.7433.7453.7390007.246109.945188.196463266471.1942286P-GPSYaw Error
348002020-03-19 15:23:03-26.09136994064628.150339732818871.5223125188.524547266422.033859255.33695042816011.395188.852631266471.85039625.0089892255.336950428-18.119214-12.526864-0.223694215.7-3.94.70011491024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223126P-GPSYaw Error
349002020-03-19 15:23:03-26.091375231134928.150331177653471.5223125188.524547266421.7206874258.4662156216011.395188.852631266471.85039625.0089892258.46621562-17.89552-12.30317-0.223694215.81.94.40010771024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223121AttiYaw Error. Compass Error. Exit P-GPS Mode
350002020-03-19 15:23:03-26.091380931678928.150322624471671.5223125188.524547266421.4075158261.72769866416011.395188.852631266471.85039625.0089892261.727698664-17.671826-12.079476-0.223694215.70.31.70010401024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223121AttiYaw Error
351002020-03-19 15:23:03-26.091385980793328.150313917939471.5223125188.524547266421.1614524264.8228431216011.395188.852631266471.85039625.0089892264.82284312-17.671826-11.632088-0.223694215.7-1.90.60010241024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223121AttiYaw Error
352002020-03-19 15:23:04-26.091391232616428.150305610194871.5223125188.524547266421.027236267.91569098816011.395188.852631266471.85039625.0089892267.915690988-17.671826-11.408394-0.223694215.6-2.70.40010241024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223121AttiYaw Error
353002020-03-19 15:23:04-26.091395853384928.150297181905971.5223125188.524547266420.915389270.84384068816011.395188.852631266471.85039625.0089892270.843840688-17.671826-11.18470215.5-2.4-0.10010241024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223121AttiYaw Error
354002020-03-19 15:23:04-26.091400733766428.15028909743571.5223125188.524547266420.6693256273.79495626816011.395188.852631266471.85039625.0089892273.794956268-17.671826-10.7373120215.5-2-0.80010241024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223121AttiYaw Error
355002020-03-19 15:23:04-26.09140499523528.150280959520471.5223125188.524547266420.5574786276.57415583216011.395188.852631266471.85039625.0089892276.574155832-17.671826-10.5136180215.5-1.7-1.20010241024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223121AttiYaw Error
356002020-03-19 15:23:04-26.091409583695128.150273139216771.5223125188.524547266420.6469562279.3996152416011.395188.852631266471.85039625.0089892279.39961524-17.89552-10.2899240215.5-1.6-1.40010241024102410242160413.7433.7453.7390007.246109.945188.524547266471.5223121AttiYaw Error. IMU heading error. Please restart the aircraft.
357002020-03-19 15:23:04-26.091413542820328.150265305370971.5223125188.524547266420.4232622282.04364419616011.1715188.852631266471.85039625.0089892282.043644196-17.89552-9.8425360215.4-1.4-1.6001024102410241024215.90413.7483.7483.7430006.78109.945188.524547266471.5223121AttiYaw Error
358002020-03-19 15:23:04-26.091417850510628.150257751103771.5223125188.524547266420.5127398284.74541593616011.1715188.852631266471.85039625.0089892284.745415936-18.119214-9.6188420215.5-1.2-1.3001024102410241024215.90413.7483.7483.7430006.78109.945188.524547266471.5223121AttiYaw Error
359002020-03-19 15:23:04-26.091421521205828.150250342176171.5223125188.524547266420.5127398287.2342611616011.1715188.852631266471.85039625.0089892287.23426116-18.119214-9.1714540215.6-1-1.3001024102410241024215.90413.7483.7483.7430006.78109.945188.524547266471.5223121AttiYaw Error
360002020-03-19 15:23:04-26.091425449064828.15024321122571.5223125188.524547266420.1995682289.75197777616011.1715188.852631266471.85039625.0089892289.751977776-18.119214-8.947760215.6-0.7-0.9001024102410241024215.90413.7483.7483.7430006.78109.945188.524547266471.5223121AttiYaw Error
Unfortunately this is all I could fit on the post
Yeah ... your story are backed up by the log. At 35sec the navHealth suddenly plums from max to 0 & the AC switches to ATTI mode ... no uncommanded movements can be seen & then at 73sec the navHealth goes to 2 & at 86sec fully restored to 5. During this whole period between 16-17 satellites were locked.
To pinpoint a probable reason for this the mobile device DAT log is needed ... look here under point 3 how to retrieve --> Flight log retrieval and analysis guide , the correct log have FLY213.DAT in the end, attach it then here.
The markers placed when the AC have switched to ATTI mode ... the yawing is commanded, exiting that you continued to climb with this happening.
And the messages:
And the messages:
Thanks for this. Yeah I decided to climb to see if it would improve the problem. But it only improved when I got close to where I was. I will try get the mobile device dat log. Not sure how to get it with just my iPad as my pc is not recognizing I’m iPad for some reason
How did you get the txt log? It's basically the same process.
I got the text log eventually by using the Airdata app but the Airdata app only shows the flight logs it doesn’t reflect anything about the mobile device dat log not sure if it can be extracted from the app
Now I'm an Android guy ... can't stand all restricted thing's with iOS, but surely you must have some sort of file explorer in your device from where you can find the log. Then either Bluetooth it or mail it to your computer ... or upload it to some web storage. Or actually go into this web site with your device web browser & pick that log and attach it to a post here ?
For some reason the file explorer under iOS doesn't see the DJI GO 4 directory. It does see the DJI Fly directory, which suggests that something needs to be updated in the GO 4 app to make it accessible.
is this file the correct file?
  • DJIFlightRecord_2020-03-19_[17-22-28].txt
fredguillot02
