HoozierDroneDaddy
- Joined
- Mar 12, 2017
- Messages
- 823
- Reactions
- 535
- Age
- 71
I may be wrong and PhantomRain can correct me if needed, but as I understand it the downward propwash keeps the lens clear of rain and snow. So protecting the aircraft from water intruding on the frame is the key issue allowing you to continue flying. Then the camera does it's job completing your flight mission.I'm assuming, for Professional work, it means to get the work done just before the sky opens up to a torrential downpour and allows you to land your drone. Maybe. But unless the plastic absorbs water, I can't see routing the water away from sensitive areas would work 100% of the time. Water has a way of getting into areas where it shouldn't. Not saying the wetsuit is a bad product, just not for me. But then, I'm in the high desert where it doesn't rain a lot and gets to be 95-110 degrees in the summer. This wet suit would not work well for me. I do like the idea of the rescue jacket though, since I fly around the river... but I haven't purchased anything like that. Probably won't
