Is there a app/program for the mini that can control individual motors?
DroneObsessed
Canada
I want to test individual motors on my Mini SE. Probably not, but is there an app/program that lets you start/control individual motors for this drone. Nothing is wrong with the drone, but i kinda want to play around with it. Thanks!
Unfortunately there is NO configurator for DJI Drones. The only checking you could do individually would be to use a Tach to check that the motors are Running their best I suppose. there is really nothing you can do with the motors as far as "tweaking" because your Drones P.I.D. is set for the way the ESC controls the motors and you cannot adjust the PID on a DJI Drone.
It might be worth checking whether or not the phone DAT is readable.
Try processing one with CsvView,
If it works the motor speeds are available.
With regards to 'playing', are you aware that an 'incorrect' speed will cause the relevant corner of the drone to rise or descend?
Reactions: Anthony Ivory
I can’t think of a faster way to crash a drone.
Everything is in sync that works faster than you could ever do it manually.
tocotco80
