Is this normal battery drain?
waverider969
just wondering if this battery behavior is normal.
charge it till its full and shuts off.
1. Store in bag and a day later plug it in to mavic and it's reporting 97% already. Discharge is set to a few days.
2. Turn mavic pro on to connect and modify onboard setting and look at stored video. After less than 10 min already showing 91% from 98% on the Magic pro battery. RC Controller went down a bit too as well (wasn't even using it)
This is concerning due to fact that unit is not even flying or propellers spinning..
I guess that's normal. All the electronics and processors built into the Mavic need a lot of power. Just touch its housing at the bottom and think at the fan which is built in for cooling the electronics.
Reactions: rajun50
The cooling fan will be running all the time whilst on the ground, the video feed, GPS and telemetry info is constantly going back and forth to the controller/phone. Yes it is pretty normal for it to drain this much.
Reactions: rajun50
magic31
