. I just attached this to mine . $1.00 on amazon.![]()
Didn't someone have a miniature "remove before flight" lanyard? That would be a good reminder too.
Make that sticker and I'll buy it!Dollars to donuts you still do it. You need to put a label right over the power button.![]()
Another Elegant Solution:
I had to buy a new clear plastic camera cover when the locking tab on mine broke off. The replacement has two built in gimbal lock "fingers" that secure the gimbal every time I put the cover back on after a flight. When you take the cover off before each flight, you are automatically removing the gimbal lock. View attachment 20069
I just ordered one of those. They aren't very much money.I never had that issue, but I got this anyways (I don't ever fly with the gimbal cover anyways so did not need the stock model) . Kills to birds with one stone.
Look at this on eBay New Gimbal Camera Protect Cover Gray Hood Cap Protector For DJI Mavic Pro Drone | eBay
DJI should put a small magnet on the cover and use a Hall sensor to check on start up if shield is in place or not. The firmware could check the status as part of startup and warn the operator before it even tries running the gimbal to its reference points.
Tech Girl
Navy jet pilot school Moffett Field CA: Student landed his jet trainer with gears up despite sign at end of runway WHEELS, flares shot off next to sign from tower and tower telling him to "check gear down". Asked why he still didn't put his gear down..."darn horn in cockpit was making so much noise I couldn't concentrate. True story.
