Just purchased Mini 4 Pro and I am in Fort Wayne, Indiana.
DanLewisFW
Fort Wayne, Indiana
I really look forward to DJI drone ownership! My brother has had them for years and I finally decided I needed one too.
I do have a possibly stupid question. I see that the Air 3 and the Mini 4 pro have the same remotes. Can you have more than one drone with one remote? I know I would only be able to fly one at a time but if I could just purchase a Air 3 with no remote it would save some on a 2nd drone. I really like the Air 3 and almost went that way, this could solve that for a little less than buying both with each having their own controller!
Someone else will have to answer your controller questions… But where do you plan to buy only a drone without the controller???
Fly On and Fly Safe…
Hello from the Crossroads of America DanLewisFW.
Fellow Hoosier here in Central Indiana. 🤝
The models and remotes have changed over the years and I'm not sure which remotes work with each other anymore. Even after giving it a Goog. :D
Other members with more toys and knowledge may pipe in soon.
Good luck and welcome to the Forum. :cool:
The thread is "Just purchased Mini 4 Pro and I am in Fort Wayne, Indiana."
@LoudThunder
"But where do you plan to buy only a drone without the controller???"
Good question I see why he asked that.
BTW,
Welcome to the forum.
Rod ..
@LoudThunder
BTW,
Rod ..
There are plenty of people selling new unused replacement drone only with no remote or other accessories. My thought was I just bought this Mini 4 Pro, if I add a Air 3 that also uses the same controller then why also buy the other controller.
I did a google search and found a response from DJI on their forum that says yes you can, you just have to switch them back and forth. I think I will wait until the one I bought gets here tomorrow before I make any decisions on that, but the idea intrigues me!
That's kind of cool, I have an Air 3 and a mini 2, and I've debated if it's worth it to upgrade to a mini 4, if I can share controllers it might be.
Still have to buy batteries and such though, I really like to have 3 or 4 batteries.
From what I can see the drone only would be 750 and about 120 per battery. So 1,160 for a drone and three batteries with the charger. A couple hundred less than just buying the fly more with the less expensive remote, which you could keep as a backup. I think that would bet the way to go. The remote is worth 150 anyway.
The Mini 4 would be about 790 for the drone and the three batteries and charger.
Welcome to the forum! :)
You can as long as the remote controller is compatible with the drones. However, you do have to re-bind the remote controller every time you switch to a new drone. It only takes a minute and could be worth the trouble if you don't want to carry/maintain multiple remote controllers.
Reactions: LoudThunder
NotSure
