Lens glass air 2s
J.C.
Canada
I was wondering if someone ever changed the lens glass on the air 2s gimbal. I know the mini it Is glued but the air 2s i wonder if it is not a clip on glass because at the bottom of the glass you see a tiny notch like you could pry it with a tiny screw driver?
It twists off like the Mavic 2 pro's doesn't it? watch
If so it is likely to be designed to fit ONLY in one way so if, on refitting, it does not seem to want to 'go'/rotate CHECK you have it the correct way up.
Reactions: EtheB
the video below shows how... it should start at minute 1:14...
everything before that is mush. Also the manual has no mention of the process.
and this video..
zenbookwriting
