Litchi AEB settings?
helloWorld
Is there a way to manually set EV steps?
Currently, there is only an option for the number of AEB photos, but not the EV spread.
It seems it's around +/-0.7EV.
Is there a way to change the value?
Same problem here with Spark. Can't even change 3 steps. The slider is stuck. Stuck at 0.7EV. Any ideas? Will you update this feature soon Litchi?
Apparently its the drone firmware that enforces the 0.7 AEB (which is way too low). Thats why DJI go has the same issue.
However, surely its trivial to update app code to just take 3 or 5 different photos at a user specified AEB range in quick succession to emulate AEB and get round this issue.
Will they do it? It's similar to how Hangar Autpilot does Waypoints. Not by using SDK.
pilot74sparki
