Livestreaming using CrystalSky via Facebook.
FredSheldon
While trying to use Livestream via Facebook I found I could enter a description using the popup keyboard but after finishing entering the description I couldn't figure out how to make the keyboard go away, which was blocking the enter button to start broadcasting. Has anybody got any suggestions?
Reactions: perry081064
i saw this on a yuneec controller.
... on that , you needed to enter the settings and change the display size ( or text size) i cannot remember the setting exactly.
then once back on the viewing screen, the menu's didnt cut off at the bottom allowing you to be able to hit the ok buttons etc.
give it a try and let us know.
...or when using the keyboard , try just touching the screen away from the keyboard or pressing the back button on an android device usually makes the keyboard go away.
Ok, I figured out what you have to do to get rid of the popup keyboard so you can click on the start livestreaming button, you need to press the settings (middle) button on the side of the CS twice and the keyboard goes away.
deepdark
