I am looking at the Mavic 3 Pro to add to my P4P's and Mini 3 Pro. Does anyone know if it has a Mechanical Shutter?
thanks
thanks
thanks
Correction only the MAVIC ENTERPRISE 3 have the mechanical shutter.The simple answer is no. Only Mavic 3 Enterprise series drones (M3T, M3E) have mechanical shutter.
The rolling shutter - electronic shutter of most DJI drones is fine for static subjects, but can distort when motion is involved.I think the question should be if it has a rolling shutter which would distort the images.
Yep, But if you read the article you will see there are ways to reduce the effects.So electronic shutter is synonymous with rolling shutter.
Technically no. Rolling shutter just means that the sensor is exposed to light line by line. Most mechanical shutters work the same way it’s just that they do this fast enough that is doesn’t cause issues for the vast majority of things. There are also electronic global shutters that expose the full sensor at the same time and thus aren’t rolling shutters but these are generally only used in high speed cameras where even mechanical shutters aren’t fast enough.So electronic shutter is synonymous with rolling shutter.
