Mavic 3T Enterprise completely new to drones
Just got a Mavic 3T and have never flown or been around a drone before. I'm full of questions.
First question is if I want to have the drone land in my hand instead of on the ground, how do I shut it off once I have it in my hand.
Next, can I see my flight path, (bread crumb trail of where I have been) on the wide angle camera view.? I can see the trail on the map view but it would be helpful to me to see in on the wide angle as well.
Woah man…you’re biting of quite a chunk there starting out with a 3T. You do a one handed double stick simultaneous shut down with the controller in your left hand or balanced on your leg. It’s good the practice that maneuver with a Mini4Pto first till you get comfortable. As for a crumb trail you can use the flight review function built into the controller but Airdata.com will give you more data than you can imagine for 6-7 a month… take it easy out there more free help on inskyphoto dot com under the “issues” tab
Reactions: RodPad
Welcome to the forum! :)
Reactions: old man mavic
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in North Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 2 Enterprise, including the User Manual.
Fly On and Fly Safe…
have the registration number on the drone.
Reactions: RodPad
I think this was my problem. I should have given the drone time to recognize my hand
Pleant of YouTube videos on how to hand land...
Reactions: RodPad
Why on earth would you want to catch an Enterprise model in your hand!
Best advice is to learn to do this so that the "5000 dollar" drone does not land in the water, on reocks, on sand, mud, whatever other than its landing pad (most preferred), but sometimes not possible when "Karen" or "Kevin" let their dog run free and you cannot "shoo" it away and they will not leash the dog becasue it just want to "say hello or it's curious..."
Reactions: RodPad
Loudthunder, you gave lots of advice, much appreciated. If I had your advice before my catch flight, maybe I would have not rushed to take off before it updated home. Phone number will be on it before the next flight. THANKS!
whathesaid
