Mavic Image Transmission Settings
FredzMaxxUAV
Seems DJI changed this a lot from Phantom/Inspire.
Who know what Downlink Bandwidth 10/20 MHz really means/does?
and what is meant by the cryptic "Cannot use 4K or High Frame Rate to shoot a video in HD mode"?
The 20mb bandwidth is a new higher bandwidth option for the live feed over the 10mb from the looks of it so the channel with now be over a wider section of the radio band, will allow faster data rates but would be more prone to being affected by other wifi
If you select 10mb you should see the data rate drop.
You can not use the 1080P live feed in 4K your limited to 720p in that mode hens the message.
Normal = 720p
HD = 1080P
Both are HD but DJI have chosen to use this slightly confusing abbreviation method.
10 and 20 MHz are channel widths in megahertz. So let's say you're on a 2.4GHz band using channel 2.439 with 10mhz width - you'll be operating on 2.439-2.449 range. On 20mhz it'll be 2.439-2.459.
Wider channels are better for higher bandwidth through-put but tend to have shorter range(distance) than narrow channels.
Reactions: sonof40 and F6Rider
what is the difference between normal mode and HD mode in the settings. Will HD provide better looking footage at lower frame rates? And does HD mode affect the transmission range?
Reactions: boxsterfahrer
As mentioned above 720p vs 1080p downlink. 1080 is likely to reduce the range somewhat, although we don't really know since we have no idea how they do it under the hood.
Personally on the mobile devices I've tested with I find the difference is barely visible.
Just a little question, the 720 vs 1080p setting has nothing to do with the quality of the recorded footage you get on your internal sd card in the drone right?
It just determines the quality of the live feed you get on your smartphone screen when flying. Is this correct?
M5P
