MAVIC LANYARD CONNECTION
Tyler Draper
Has anyone come up with a way to create a lanyard mount for their controller yet?
A few of the tablet mounts include a lanyard hook, but otherwise haven't seen anything intended solely to do this. Check out on eBay if the tablet option interests you.
Reactions: SeaFox
I use a Secraft transmitter tray with a Futaba 14SG with another drone and a Sony Z3 tablet. I cobbled up a wooden adapter to take the Mavic controller instead. A little rustic, but works quite well.DSC07926.jpg DSC07929.jpg DSC07930.jpg
So I went with the Peter Holmes solution. Felt like making something today. A little bit of paint and I'm done.
Thanks for all of the suggestions guys!
Reactions: Drseussami
Yep.
Never understood how people were happy with a lanyard between their eyes and the all-important screen...
Convenience. Not having to hold or look for a spot to set the controller down when not in use...
That wasn't the question, having a lanyard is sure nearly mandatory, but why put it right in the middle in a way that prevents you from operating the thing comfortably?
To each his own I'm fine with where it's at. doesnt hinder my operation one bit.
Reactions: SkyHigh Pryo
My free zip tie solution keeps the lanyard away from the screen and has an added advantage in that the controller and iPad is perfectly balanced too.
Building on what SteveCa posted I used the original DJi strap that comes with the case. Just disconnect from the case and insert through the Controller arms.
Reactions: Daptone
Zip ties or the loop it around the transmitter arms. The lanyard mount you can buy looks like once you mount your lanyard to it would obstruct your view.
tabarton94
