TDZHDTV
Mine weighs 242g
Mine weighs 242g
Honestly I've had the MM since march and although I love it's portability, If you're serious about videography than the Air 2 is miles ahead. Wind resistance is in my opinion is a massive argument.
Well, I am also a bit disappointed. On April 20th, I bought the mini combo pack. About 5 months later, DJI releases a new version of the Mini with better specs, and it appears it is now abandonning support for the numerous Mini 1 owners. What e.g. about the battery temperature issue in the DJI FlyApp?
So here's what I got based on what I can find from online sources:
- Mini 2 has faster overall speed topping at 16 m/s
- Minimal increase in battery life at 31 minutes vs. 30 minutes
- Level 5 wind resistance (>8.5 m/s) vs. level 4 (8 m/s)
- Mini 2 has 4k recording up to 30 fps
- Mini 2 has up to 4x zoom, lossless at 2x
- Video Bitrate is at 100Mbps vs 40Mbps
- Mini 2 can now shoot RAW
- 10km flight range vs. 4km
- Video transmission system now utilizes OcuSync 2.0 with 8 Mbps max bitrate
- Added features include Panorama, Enhanced Photos (not sure how this works), and Trimmed Download (can cut long clips directly from DJI Fly app)
Size and weight are still basically the same. The Mini 2 is priced at 449 USD for the Standard Package and 599 USD for the Fly More Combo.
How would you stack the Mini 2 vs the Air 1?The Mini 2 is definitely better than the Mini 1. If I had known back then what would happen now, I would have, could have, should have, waited.
But no sense abandoning the Mini 1 for now. Still enjoying this little bugger.
Maybe the next upgrade I should be looking at will be the Mavic Air 3? Hmmmm ? ?
$$ Mavic Air 2 still nearly 2X price of Mini 2...$1140 delivered w/goobermint theft (tax) included. The advantages of 570g drone begin with collision avoidance sensors. There are many more but have dwindled a bit with the release of Mini 2. When DJI enables a Combo Kit without another exact same Controller (who needs two) Ill buy a Mini 2. Who needs collision avoidance over Iowa cornfields.The Mini 2 is definitely better than the Mini 1. If I had known back then what would happen now, I would have, could have, should have, waited.
Maybe the next upgrade I should be looking at will be the Mavic Air 3? Hmmmm ??
2250 v 1100 mAH batteries Mini 2 V Mini. The stronger motors need more juice. Li-Ion generally have more capacity, however somehow the Li-Polymer batts on Mini 2 have double the capacity. Im afraid the Li-Pos will quickly lose holding capacity. The regimen on recharging will be important to accertain. I.e. do not allow batt to fall below X% or discharge to below X% before recharging? I expect the latter.They are Li-Pos for the Mini 2
Only the Japanese version of the MM1 has 1100mAh batteries, and these are quite rare. All other versions have 2400mAh batteries.2250 v 1100 mAH batteries Mini 2 V Mini. The stronger motors need more juice. Li-Ion generally have more capacity, however somehow the Li-Polymer batts on Mini 2 have double the capacity. Im afraid the Li-Pos will quickly lose holding capacity. The regimen on recharging will be important to accertain. I.e. do not allow batt to fall below X% or discharge to below X% before recharging? I expect the latter.
Did you put it on a scale before and after? Why would removing the foam make it more rigid? Why would you remove the foam?
Li-Ion batteries are heavier than Li-Polymer. 1100mAH vs 2250mAh with Li-Po. The fact that they are interchangeable means you can use Mini1 batteries. No other advantage other than you've got emergency/as needed spares.Are you sure about it being heavier? Mini 2 specs are that its 242 grams with battery and SD card. Seems lighter to me.
What he’s trying to say is DJI have redesigned the AC, it no longer has foam inserts. I would describe the front arm as rigid now, in fact I suspect DJI have changed the plastic as the overall drone build quality seems much improved over the M1.Did you put it on a scale before and after? Why would removing the foam make it more rigid? Why would you remove the foam?![]()
