Mavic mini 2 battery in mavic mini 1
@DavidMendoza its not just about the battery physically fitting into the housing the actual battery voltage is different and the cells themselves use a different chemistry ,and there will be a incompatibility with the BMS in the battery, and the drone ,when they communicate to each other when the battery is turned on
Ditto OMM's post.
From what I have seen written the Mavic Mini, however shelled, will not allow the use of Mini 2 batteries or, perhaps, Mini 2 batteries will not allow themselves to be used in a Mavic Mini.
Sorry, if the shell change was for this reason alone you wasted your time.
deepdark
