Mavic Pro Camera - Help!!
cmallarino
Hi guys,
I´m having trouble with my Mavic Pro Camera. The videos I take aren´t smooth as I would like when rotating the drone, even with very small movements, the final video turns out with some kind of bumps in the fluency of the video (as if i was to stop the drone suddenly and then continue rotating it, even though i don´t).
I already recalibrated everything (Gimbal, IMU, Compass, Controller and reset camera settings), but nothing seems to solve the problem.
My current firmware is v01.03.0900
The video was recorded in 2.7K at 30 fps. I don´t think it is a frame issue because the image transmission to the controller seems to be the same.
In the link below you can see the videos with the problem.
Also I would like to know if this "jello" effect on buildings when start rotating the drone is normal! This was taken on P mode not S mode.
Thanks!
Hello, I also have the same problem, could you tell me if you have solved it?
Thanks and best regards
dcjz
