beanbubba
- Joined
- May 7, 2017
- Messages
- 1,845
- Reactions
- 1,407
Sure thing. It's a gig in size and I have slow internet, so it will take a while.Can have a copy of that data file?
OK, that file is 220MB and uploading now.just the 049 dat. Its only a 650 sec flight that one should be small
That's great. You may have to do it more often because of the longer than normal flights.@BudWalker, your FileZilla cleanup procedure works. It appears you have to do this every half dozen flights or there abouts.
What is the weight of each pack? 4 x TP4500 4s should be under 1300g without the wrappers for 18Ah.
FLY5542.DAT
If I was going to continue yes it probably needs cooling but unfortunately, I think I'm done with this mod. When I took off for this flight and it was under load I heard the dreaded vibrating noise that took me down more than once before. I don’t believe heat is causing my issue because It was at takeoff, I believe it’s some kind of current limiting or some other limiting factor. It could even be my esc is toast idk...I started this mod to see how much battery I can carry to get as much usable flight time as I could. If I just wanted to go up slow and make no fast movements and get a long hover time this is ok but for normal fast forward flight with a lot of mah hanging this isn't working for me...
@beanbubba if you continue with this mod good luck man! I hope you get it working! But if you quit, believe me I understand…
Pulse width ModulationI wonder what PWM means. Power something and the left front is hitting 100% at the same time as the high current
Can those mushroom antennas be uncased? They must catch downwash from the front props as well as creating drag in forward flight.@beanbubba @chazz and everyone else that tinkers and pushes the limit. Thank you. I’ve scoured through so many posts, topics reading the ups, downs, successes and failures and really have enjoyed seeing the progress you’ve made. In no attempt to hijack the thread but having the battery experts in one place makes this an easy place to ask your thoughts on my idea.
First, I have a Mavic AIR. The red headed step child of the DJI family, I love this little bastard however and wouldn’t trade it for any other model. I am however envious of flight times and I love mod.
Currently for the RC I have a 2.4ghz Titan Cyclone, and I also have a 2nd 5.8ghz Cyclone. The AC itself has been modded removing the original antenna in favor of high gain 5.8ghz mushrooms.
View attachment 43043 View attachment 43042
I can reach 10-12k ft on 5.8ghz with reasonable ease before the drone freaks out about RTH due to battery life remaining and here is my question and request for input.
I have 8 DJI batteries total for my AIR through some luck and seeing your progress I had an idea. I’d like to take 2 or 3, and condense into 1. IE take one apart and it becomes “master battery” then take the cells from the other 2 and attach them to the master. I’m confident that I could print a nice design to hold the cells on the sides of the drone but I’m more worried about connecting the batteries together. Another thought is that I have an extra 5.8ghz booster on have and it’d be awesome to put that on the AC as well. If I could and everything could work as I envision I’d have a 1 battery’s cells on each side and place the booster under the back wing, making a riser for the spoiler of sorts.
Opinions? Thoughts? At a high level can I even combine the batteries cells together?
Thanks again!
Will
Thanks again!
Will
They could, but I ended up breaking one and I’ve got the AXII stubby and VAS iON to test. Both significantly smallerCan those mushroom antennas be uncased? They must catch downwash from the front props as well as creating drag in forward flight.
