thanks for the reply,issue sloved,just follow Maverick78's guide,the only thing is that the precising landing is not working now,is yours ok?What firmware are you using to downgrade? did you removed the mentioned modules from it?
understood.Precision landing won't work because you're flashing the old flight controllers, who doesn't have the precision landing feature
Hey Maverick, I'm just going through this whole process now with my MPP. Can you tell me which mods are activated in your version of the .22 app? CheersLink to the modded Djigo i use :
DJI Go 4.1.22-mod.zip
Hy i never could see my Firmware with dji sssistantHi guys, I followed the procedure to rollback Mavic Pro Platinum and modify height limit.
After installing SD card I downgraded from 1.04.0300 (original) to 1.04.0000 (original) and from there to 1.03.0700 (mod, no 1200,1201,1202,1203 modules). Modified height limit parameter and afterwards flashed modded 1.04.0300 (no 305,306,905 modules).
I got 'motor current error', wasn't comfortable with that so I did a factory reset and flashed back the original 1.04.0300 to finally have some fun with the new toy without messing with in its' guts.
Then I got back to the idea and followed Steven Lawyer's tutorial here Rooting Mavic Pro in Latest firmware with Force FCC and Boost and No NFZ - RC Groups
In step 3 "Flash FW.700" I'm not able to get DUMLdore 3.07 to show the 1.03.0700 fw installed. Flashed it like 10 times and it always say I'm on 1.04.0300. Tried other versions of DUMLdore run on either Windows 7 or 10. Same result.
Actually even after I flash back the original 1.04.0300, the DJI Assistant 2 (1.1.2) is unable to show me what version I'm currently on.
The NLD MOD Client 1.7.0.1 states that it cannot identify my fw version and shows these version info below.
After flashing original 1.03.0700:
{"DEVICE_MODEL":"wm220","MODULES":[
{"MODULE":"Camera4K","FIRMWARE":"2.6.484"},
{"MODULE":"Camera4K_Loader","FIRMWARE":"2.6.484"},
{"MODULE":"FC_Loader","FIRMWARE":"34.4.0.23"},
{"MODULE":"FC","FIRMWARE":"3.2.30.13"},
{"MODULE":"Gimbal303","FIRMWARE":"1.50.12.1"},
{"MODULE":"1860","FIRMWARE":"1.5.0.20"},
{"MODULE":"CPLD","FIRMWARE":"0.0.4.8"},
{"MODULE":"UltrasonicM0","FIRMWARE":"1.0.0.8"},
{"MODULE":"CP","FIRMWARE":"47.26.2.11"},
{"MODULE":"Battery0","FIRMWARE":"1.0.18.16"},
{"MODULE":"ESC0","FIRMWARE":"0.0.0.0"},
{"MODULE":"ESC1","FIRMWARE":"0.0.0.0"},
{"MODULE":"ESC2","FIRMWARE":"1.1.0.71"},
{"MODULE":"ESC3","FIRMWARE":"1.1.0.71"}]}
After flashing original 1.04.0300:
{"MODULE":"Camera4K","FIRMWARE":"2.10.519"},
{"MODULE":"Camera4K_Loader","FIRMWARE":"2.10.519"},
{"MODULE":"FC_Loader","FIRMWARE":"34.4.0.24"},
{"MODULE":"FC","FIRMWARE":"3.2.44.7"},
{"MODULE":"Gimbal303","FIRMWARE":"1.50.12.10"},
{"MODULE":"1860","FIRMWARE":"1.6.0.35"},
{"MODULE":"2100","FIRMWARE":"1.1.0.2"},
{"MODULE":"CPLD","FIRMWARE":"0.0.4.9"},
{"MODULE":"UltrasonicM0","FIRMWARE":"1.0.0.11"},
{"MODULE":"DJI_Vision","FIRMWARE":"1.3.0.99"},
{"MODULE":"CP","FIRMWARE":"47.26.2.18"},
{"MODULE":"Battery0","FIRMWARE":"1.0.18.24"},
{"MODULE":"ESC0","FIRMWARE":"1.1.0.71"},
{"MODULE":"ESC1","FIRMWARE":"1.1.0.71"},
Have you encountered similar issues? How can I get DJI Assistant to show the current fw version or NLD to identify it properly? And finally what could be wrong that DUMLdore does not show the .0700 fw after flash?
yeah, that's a known issueDJI Assistant 2 (1.1.2) is unable to show me what version I'm currently on
you need to have newest DJI Assistant installed if you want to check FW version, but since you use NLD client, you can just believe what it says
so if you wanna try it too, then:
after you get root with DUMLRacer, in step 6 you check it with adb shell command
and then, in step 3 (it's called STEP 3: Flash FW.700), there is a link to file V01.03.0700_no_905_Mavic_dji_system.bin
download it and remove from it all modules except 0305 and 0306 (and that wm220.cfg.sig file)
flash it with the newest DUMLdore
after it's done, check in DJI Assistant 1.1.2 that modding is possible for all the parameters
then you can continue with STEP 5: Remove the NFZ Files
I'm glad it workedHeight_limit parameter in DJI Assistant is visible so that's a success
You locked up the bird, And lost its comms drivers, And also corrected the drivers you were using on your computer probably. I’m assuming the main light on the back is a steady red, once the bird is Initialized.Hi, I have a big problem.
Yesterday I downgraded my MPP to 1.03.0700 (installed an SD card before). I had to use DD 2.12 for the step from 1.04.0000 to 1.03.0700. I did a little testing with height and it worked fine.
Today I was trying to update to 1.04.0300 (without 305, 306, 905). I did use DD 3.1. The first try went good and I went out for testing. Almost crashed it because somehow the sensors where not working (no protection at all). OK I thought let's do the upgrade again but now it was stuck in the flashing process at 99% and kept connecting and disconnecting (the USB chime) all the time. I waited 10 mins and then powered off and disconnected.
After that nothing works out. I can't get any connection to the RC nor connection to the PC via USB and the fan does not work any more.
Any ideas how to come out of this.
Out of curiosity, WHY do you want to downgrade?
After this happens immediately update your software for me I updated to version 1.4.100 then back down.
Use assistant 2 to reload the firmware at 1.4.100 that way it gets a good clean copy, then redo the downgrade and upgrade again.What program for the update? DJI-Assistant2 or DUMLdoreV3
