Hei. I'm hoping to find answer regarding the solid red light my mavic pro is having. it happened after I downloaded the upgrade. since then I could no longer connect it to the remote control and the red light remains since then.
It means an error that is not user fixable and requires work by DJI. May be fe few more details in the full manual available online only.
Best of luck.
if you are comfortable remove the boards and wash thoughroughly with isopropanol alchohol and a toothbrush until they look very clean and then blow out the motors and gimbal motors with compressed air.
Try that but if it ends up working It might be a bit risky as salt water can do a lot of damage and the drone could end up crashing after.
Distilled H2O first to dissolve salt then alcohol (isopropyl alcohol is a weak solvent for salt, water is very good at it). Use the isopropyl alcohol to help the water evaporate a lot faster, But don’t get alcohol on the lenses though, it can fog plastic and objective coatings.
Dukegotit
