Mavic RTH point moving without the Mavic even running.
I brought all of this up because I had not noticed the location fluctuating while sitting on the ground. So if you sit the Mavic on the ground without starting the motors, you will watch the indicated distance go to 30' within a minute or two? This happens daily.
If this is happening with everyone, then I just never noticed it. 30' seems excessive.
Thanks for all of the input.
Many people get hung up on the number of satellites the gps is receiving. In truth all you need is three to provide a location (four for altitude). Time, very accurate time (thus the need for atomic clocks) is needed to insure that when a measurement is taken from the three satellites it is at the exact same time. This creates a triangulation that can now calculate your location.
The fact that all of the GPS Satellites are in constant motion means that the triangle on which the accuracy depends is constantly changing.
The ideal configuration for the three satellites being used is 20° above the horizon and spaced 120° apart, although this rarely happens and if so only for a short period of time. Many hand held GPS receivers will show you the position of all the satellites the receiver is collecting data from and on a separate page it will show the strength of the satellites (it will also give the # of the individual satellites). Some units will give you estimated accuracy in feet.
This is where the movement you are seeing comes in. As the satellites orbit the earth the shape and size of that triangle is constantly changing and further from the ideal spacing mentioned above the less accurate the calculation.
This is a layman's explanation of GPS positioning and it much more complicated than this as I'm sure Alan and others will point out.
Bottom line if it bothers you don't zoom in so close and you won't even notice it. If it still bothers you get a new hobbie because all the calibration in the world on your Mavic (or any other GPS device) is not going to change it.
Noob question!
Do you/should you set the home point manually even when the Rc says” home point has been set”?
The ac symbol is to set it where ever the ac is at the time and of setting it.
The person symbol
Is wherever the remote is located. (To use on a boat that changes locations for example.
Mike
Is this a question directed at me? If it is, no, I don't normally do it manually, only doing it now so that the distance indicator shows how much drift is occuring in my situation.
Noob question!
The person symbol
Mike
Does your fluctuating position occur at every location where you fly? If you've only noticed it and tested it in one location, like at home, you need to test it elsewhere, away from metal objects and concrete.
deepdark
