Mavic2 Radio & Antenna Mods
Hello. Regarding the antenna leg flip is it only nessacery to do the left leg or would there be an advantage to turning the right leg too.:)
15491489205877761985833465770932.jpg15491490760026578103766823086447.jpg15491491519443321516986621133195.jpg15491494676567109453339384212322.jpg15491496157361951299753993480372.jpg
I managed to angle the left leg by inserting an angled rubber spacer between the screws and with using 2 longer screws could keep it in its original position with the led still facing forward. The thickest part of the spacer at the back makes the leg move forward. Tried it today and signal does seem better. Sorry if photos are blury.
View attachment 61555View attachment 61557View attachment 61558View attachment 61559View attachment 61560
Looks like you figured it out. Nice work.
Thanks beanbubba. What’s your opinion of the right leg leave it standard or angle it the same :)
Hi beanbubba. I’m sorry to be off topic here and bother you with this but i modded my mavic 1 controller with 2 amps. Realising now i only need to have one on it. I was wondering if i do the birdside amp mod on the mav 1 looking at the bird from the front which ant should i amp. the left or the right. Many thanks.
Thanks beanbubba port and starboard understood. So from the port side main board to the amp. Then from the amp to the antenna. Same principle as the remote amp mod then.
Dual band first?
I must say it is a pain to hard set 2.4 on every single flight (just remembering to do it). The dual band sunhans makes it stress free, but it is middle of the pack in performance. I have now taped a yellow sticker on my RC stating "SET 2.4 RADIO" :cool:
Yeah I wish there was a feature to have the radio settings persistant. In my area, 5.8 always works better. At 10km out if it switches to 2.4 the signal can be lost and the M2 seems to have trouble reconnecting.
joel_du05
