Mini 3 Pro gap between motor and frame
thanostc
GREECE
Hello to all! I just found out that one of the two rear motors has bigger gap from the frame... i don't get any errors or anything, just to confirm if any of you has something similar! Thank you!
Hang on.... I'll just check.... Yup! about 1/8th of a millimetre difference between the port and starboard motors and motor mount (front arms). Barely noticeable.... But definitely there. No in-flight weirdness either.
This is just guess work but have a look at the tops of the motors.
Is there a shaft end visible in the centre of the motors? If are do those shaft ends sit at the same height relative to the tops of their motors or is the shaft end on the motor with the bigger gap 'lower' in the top of its motor than the other motor?
It's probably also valid to make comparisons with the front motors, I would guess they are the same motors but that is a GUESS.
Reactions: thanostc
GMvK
