Mini 3 Pro lost at sea...
jmrmavic2
Hi everybody, I am following most mini 3 Pro threads for a while now and I had an issue with mine yesterday when launching from back of sailing boat.
I have some experience with several bigger Dji drones in the past years without any issue, but this was my first mini.
Hand launching from the back deck it took off but lost power and lift almost immediately and it fell in the water without any chance of recuperation.
The wind was 3-4 Beaufort,...I had checked all safety settings before launch and had plenty of satellites.
There was no home point set yet because RC screen showed that ac was moving(sailing), I was expecting a home point setting once airborne.
Although home point at sea is to be reset from time to time.
Wondering if I made a pilot error or this could be hardware fault?
Thanks anyone for any advice, hope you can open the file.
Greetings JM
@jmrmavic2 ,there is an anomaly with the Mini 3 when hand launching ,and that is not to give it any upwards movement at the moment of launch ,or do the opposite and move your hand down to quickly at the moment of launch ,in both instances the motors stop
although you may not have done either of those movements intentionally ,unfortunately the pitching of the boat would have had a similar affect
I saw a youtube review saying you could not hand launch this drone. Maybe it was that?
Thanks for replying, must have missed or payed no attention to this part in the manual, the pitching of the boat must have caused that effect, never had any problem with handlaunch/catch on solid ground before.
Dji support is still analyzing log...
Thanks again for helping to understand!
The TXT file as per the phantomhelp link post #8.
Sorry for your loss, that would have been terrible watching that happen.
Even though it would have been seconds, it must have seemed like slow motion.
Beaufort 4 is approaching the mini 3 pro lower end of its wind rating, I would be very cautious with gusts around that anywhere, but even more so from an ocean going vessel.
Did you take up Care Refresh ?
Found Aircraft Flight Record Cache in RC Internal Storage but only possibility is to clear cache, usb file transfer is turned on.
RC SD Card contains only Photo Cache and Album Data and can only be cleared also, so no transfer possible...
Remembered last night also that I had a message in red on top of the screen saying "ac is moving" or something like that(at that moment take off was not possible), caused by the moving ship, but after a while message changed to "Take off permitted"...
So that is why I am als doubting it could be a hardware issue.
Screen recording was not active.
I have Care Refresh, Dji support already downloaded the logs from the RC and will report in a couple of days, they will see this "take off permitted" message also I hope.
Put the RC on USB at your Computer and switch it ON.
Than you can see under "This PC" -- "DJI" "Common use memory"
Here are the flight Records.
Can't find anything similar on the Mac:( sorry, but will post Dji report here soon.
I think you need to use something like Android File Transfer when connecting an Android phone to a Mac ..... though I can not get it to work for me lol. Might the same thing apply to the controller i.e. might some form of program be needed on the Mac to allow the controller to be read?
@jmrmavic2 have you seen this thread
Reactions: Octisurfer
erhard
