My SC setup is finally complete
This is my latest setup (attached) (beer optional), yes I know everything is dark (ND filter fitted) but I'm currently just going through my settings & learning as I go along from YouTube - Loving it...
HOWEVER... I did receive a "Link phone number" message (attached) this evening after flying the DJI Go 4 simulator & was asked to enter my "Chinese" telephone number (I live in the UK) which wouldn't go away!!! I did a search on Google & it seems to kick in if you fly the simulator & the best advice I found was to log out of your DJI account & then log back in again & check your country of origin - seems to have fixed it! Anyone else witness this??
check out this sick setup... this is how im getn mine done...
Have you seen the amount of work involved stripping the smart controller to fit this antenna replacement to the smart controller???
Think I'll stick with what I have...
Reactions: Sneaks99
i sent mine to a drone tech shop in HK,recommended by Alientech ,took about a 2wk turnaround & work was professionally done w/1yr guarantee...! no issues yet soo far...
I bet it wasn't cheap... is it better, if so, worth it???
not at all...$120 install,included is bracket accessory,qma jacks,(round trip shipping)returns your original antenna ,can be retrofitted back to original way...best mod soo far...!i highly recommend it if your lookn to boost the SC....high quality work & materials....
Reactions: RickJH
Oooh, one to consider perhaps. Is it true you can fly securely in wooded areas where signal is weak? Where did you buy it from originally & how did you arrange it? (links pls would be good if you can)...
swipe down on SC screen hold finger on HDMI icon and a drop down menu will appear for HDMI output options.
if you got the 550 battery it don't last long, I got a 970 and it lasts forever
Sorted! Thank you!!
Oooh, one to consider perhaps. Is it true you can fly securely in wooded areas where signal is weak? Where did you buy it from originally & how did you arrange it? (links pls would be good if you can)...Lifthor SC/Pro is from ThorsDroneWorld,Alientech 2.4 or 5.8 or Duo booster,SC controller bracket istall if from PlayConcept HK
Reactions: RickJH
BentenL
