- Joined
- Jan 4, 2017
- Messages
- 70
- Reactions
- 47
I had a scary flight this morning. I was shooting an Indian Temple Statue in Malaysia. Half way through the flight, DJI GO 4 Apps said "Aircraft Disconnected", I couldn't see anything from my DJI GO 4 Apps.
I tried closed DJI GO 4 apps and reopened again, it couldn't connect to my Mavic Pro. I tried to look for the Mavic location but can't really judge where was it located since my concentration was on the screen taking the footage. Here is the map and the flight logs
"H" was the took off point, I tried to look at Yellow area to locate my Mavic, because I wasn't sure where was it located. I was in panic mode, still can't see it anywhere at the Yellow area. After a minute or so, I tried looked at other area where "T" was, then I saw a Mavic hover in the sky.
There were couple of Mavic and Phantom crafts around, not too sure was that mine. I tried move left and right on my RC stick, the movement seems like what I controlled, then i tried move toward me... and YES, that was my mavic. At that time DJI GO 4 apps still not working, status were still "Aircraft Disconnected". Besides, there were no RTH trigger on the Mavic too ;(
As you can see, the flight record ended at "T", in theory the Mavic was stuck there. Lucky I was able to identify my Mavic Pro and slowly brought it back to me.
When the Mavic was above me, I tried to power off the RC and power on again, I was able to connected to Mavic Pro on DJI GO 4 Apps again. I was thinking to power off/on the RC when I saw the Mavic from far, but worried it couldn't connect it back, since RC still have control. It was best to bring it back.
It was a scary experience. It's the same bad experience the guys had while shooting The Bund at ShangHai.
Refer to the picture below, I was controlling 2 meters away from the tent in red square. The LOS was clear between my RC to the aircraft, there were no tall building around.
Below is the footage.
The flight record data can be downloaded here.
I will log the problem with DJI Forum. See what do they say on this.
Lesson learnt. Always fly at your line of sight. Phew..
